BHD108ExplorerMay 27, 2018Started renovating....can everything be replacedI recently purchased a 1997 Wildwood 5th wheel. It's about 27 FT. I wanted to remove the flooring and fix it up a bit as I feel there is some mold and mildew. I took the bed frame apart, had to des...Show More
bid_timeNomad IIIMay 27, 2018No, you won't find pre-made panels to replace the existing panels. You'll have to fabricate them yourself.
Related ContentCast-iron..Everything everything sticksReplace insulation inside heater column.Water Heater Replacement RecommendationsRef freezes everythingCheck EVERYTHING
