byrdr1
Aug 23, 2014Explorer
I installed my steadyfast one muggy SATURDAY, Front end was not much of a problem. Had to mount it backwards from instructions due to gas line. back was a bit more because I have a cougar with the slide out bike/storage rack. I had to have the back bracket welded and then spaced to clear the slide out. real time with all the sweating was around 4-5 hours. I followed instructions step by step so that I did not screw anything up. Also don't forget as you install the screws/self-tapers to use the locknuts the first time that will cut out some install time. :(
Cant show any pictures as I dont have website with my pictures on it anymore.
stevewatr, good videos and they should help someone to install steadfast system.
I do have pictures of the welding that I had done about two Saturdays later. Had to find someone who would weld it and drag the camper to their shop. I had everything ready to install after the welding, so that was quick and easy. about 15 minutes for that..
That welding was the only real problem I had installing mine.
IT has made a difference and you really tell it.
randy
randy
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
