Likes to tow said: "I actually use a pad lock on my B&W instead of the pin. I'm afraid someone will remove my pin while I'm not looking and then watch me drop my 5th wheel on the truck bed."
I can't tell you how many times I have been given CHITZ for my locking of so many items!!! Good idea that you add locks to the head also IMHO.
FYI the head pins need to be bent at a 90 or they can simply be rotated and pulled out. They are not bent in pic below. I heated mine with a torch. Had to drill holes out a bit larger for the lock and countersunk the holes a bit on each side.
