Old-Biscuit
Nov 28, 2014Explorer III
ScottG wrote:
I've never seen a check valve on a three valve system - there would be no reason for it.
I suspect you still have a valve in the wrong position. Try turning one to see what heppens. If no luck then keep trying.
X2
Think that cold inlet OR hot outlet valve handle is stripped.
Handle turns but valve is still closed
IF sure water is in WH tank---verified by opening relief valve then the hot outlet is still closed.
Remove handle and open valve using pliers on valve stem.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
