Dakota98
Nov 28, 2014Explorer
portliz wrote:
After running through some problem solving steps we think it might be a check valve. We did a combination of open and closed valves. There is hot water in the water heater. It has pex lines and valves. We think the cold in line valve was put on wrong ( just checked and winterized by rv dealerhad it ). Once we put the cold valve the wrong way!!! We have water again from all taps including outside shower but not hot. It is so awkward to see and get to. Guess our next step is take it to an rv repair place. Anyone know a good one near Troy Alabama. Thanks for all the suggestions.
"We think the cold in line valve was put on wrong", just had it checked & winterized.
Was this by-pass system just installed or repaired at the time ?
If so, that would have been good information in your original posting.
Water pressure, but NO hot water & inlet valve in "closed" position, but is really "open", and in consideration of what you've described earlier.
Then the By-pass valve is also wrong.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
