pcm1959
Jul 19, 2016Explorer II
I had the Kodiak on the Cameo. They are single piston calipers and use GM brake pads. I had the Titan pump on that set up. The "lad" was nil.
My Lifestyle came with factory installed Dexter with their pump. I can tell the difference as there is a bit of lag. Eventually, I ant to replace the pump.
I think the Dexter brakes may be better since they are dual piston but they cost more and the pads can only be gotten from Dexter. I say this because of have read of occasions when the Kodiak will hang-up and I've not heard of this with the Dexter.
What ever set-up you get, get the Titan pump and run a larger line from the pump back to the axles at the split.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
