4x4FF
May 14, 2015Explorer
Storage Box Input
Hi All, I am looking for ideas/input on a under chassis storage box I am going to make for my 5er. First off what I am looking at accomplishing is storing my Ladder and BBQ Grill. If I can get th...
DutchmenSport wrote:
Correct me if I'm wrong, but do you mean (8" X 24") 8 x 24 (feet or inches?) Double quote is inches. Single quote is feet.
If inches, that's pretty small, only 8 inches by 2 feet? But, 8 feet wide by 24 feet long, that's pretty big?
The dimensions of length and width are not so critical. However, (if 8 x 24 feet) and you have to access under the floor, you may have a challenge removing the box (which may never happen).
I'd be more concerned about how "deep" the box is. You need to make sure you have enough clearance between the bottom of the box and the road so you won't drag it. So it really depends upon how "deep" you make it.
Your idea should work, I don't see any reason why it should not. It looks like you already have a storage container under there. If you go with the same depth, I don't think you'll have any problems. with either ... 8 x 24 inches or 8 x 24 feet!
