- Michelle_SExplorer IIIWe originally thought they were silly, until we had one, now wouldn't be without one.
- Retired_JSOExplorer IIIf you ever use it, you will miss it for sure. I didn’t think we would use ours but here in the north Georgia mountains, even in summer we use it to knock off the morning chill.
- cummins2014Explorer
johndeerefarmer wrote:
jpmyers wrote:
We want to remove the fireplace from our 2020 Highland Ridge Silverstar. This rig has precious little storage. We won't get much use out of this "fireplace" and that cavern behind it would make a great cabinet!
Since most campsites we go to include unlimited electricity we use the fireplace to heat the camper instead of expensive propane. I would reconsider leaving the fireplace for that reason and carry less stuff with you
Same here , we are nearly 40 miles from the nearest propane source , and that fireplace gets used a lot on the RV parks dime ,not mine. Its one of two things either we haul an electric heater , or a built in fireplace. I will take take the phoney fireplace . - jpmyersExplorerI've thought about that option. I may go that route I can get the wife to buy into it.
- Michelle_SExplorer IIIHow about putting hinges on one side of the Fire Place and a latch on the other, build your storage behind it in the current dead space and have the best of both worlds.
- johndeerefarmerExplorer III
Since most campsites we go to include unlimited electricity we use the fireplace to heat the camper instead of expensive propane. I would reconsider leaving the fireplace for that reason and carry less stuff with you - TXicemanExplorer IIThe big problem with a fireplace is is it does not heat any better or any more than the 1500 Watt ceramic heater. With the ceramic heater I can move it from one end of the trailer to the other.
For reference, 1500 Watts is 5100 BTUH and that is all you will get from a 15 amp plug on 120 Volts.
Ken - cummins2014Explorer
FlatBroke wrote:
cummins2014 wrote:
FlatBroke wrote:
We had to with Fire places, current one without. We miss the fire place. Storage? Looked all the stuff We had and to about half off it out. I’ve got A lot of empty cabinets.
Kind of the point I was making, all the unnecessary junk we haul. I wouldn't give up my fireplace to haul more STUFF . We use our fireplace a lot, it puts out more heat then some of those space heaters, has a blower on it. Then you are faced with a space to put the space heater ,mostly like in the space where the fireplace was :)
Come to think about that space IS where our two heaters are stored. :)
It only makes sense. :B For us there is just no way I'm pulling that fireplace for anything. We spend a good portion of the summer in Montana. The temperature this morning was 40 degrees as it is many mornings here. On goes the fireplace nearly every morning. It rained all day yesterday ,and was chilly all day, all was needed was the fireplace.
Our fireplace is far from phoney as far as heat, its actually quite an electric heater with blower . - CA_TravelerExplorer IIISince we're retired and travel for many summer months we carry a lot for convience and comfort. We don't have to have a BBQ and Smoker but enjoy both and no doubt other stuff that we could shed.
Now my garage definitely has unnecessary junk but I never know the needs of my next project...:B
And we did shed the useless CareLess awning in the wind last summer! - FlatBrokeExplorer II
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
