srgt30 wrote:
Thanks for sharing your setup Yellermanx, looks perfect for what I would like. A couple of questions though, after you get it in place the straps hook through the d-rings? And what are the eye bolts for? Thanks again
The eye bolts hold the chock to the angle. The nuts are only finger tight. If you look close at the threaded part you can see a hole. I put a hairpin type clip in there to keep the nuts from coming off. I don't believe the nuts are even needed as the straps pull it all tight when the bike is in it.
I put one set of straps to the eye bolts and another set to the d-rings. Just over cautious I guess.
