cummins2014's avatar
cummins2014
Stuck Caliper Piston
Well here goes again , a leaking tire on the fifth wheel got all this started, while the tire was off thought I would pull the hub to see what size grease seals I would need to pack the bearings. What I discovered was a broken plastic dust cap, and worn out disc brakes. Bought the four new grease seals ,and 2 new sets of disc brake pads.
All went well on the first one ,packed the bearings ,changed the pads ,I put a clamp on the caliper piston to push it back to give me enough room to get the caliper back on , no problems . Proceded on the second one, got to the part where I clamp the piston back for more clearance, and it will absolutely not move, even put a cheater on the clamp no go. Never had a caliper piston before that couldn't be pushed back in . Anyone have any suggestions how to get that piston to release ??
  • Just replace the caliper.
    A sticking caliper will make the pads drag, causing over heated brakes.
    Or, loosen the bleeder screw while pushing the piston in.
