GoPackGo
Apr 09, 2015Explorer
I just replaced the anode on mine. There was LOTS of crud in the tank and I figured some of it had to get lodged in the threads even after flushing. So I got the 'firmest' toothbrush I could find and spun it around the threads several times. I know this won't fix buggered up threads, but it will get any sand or grit out of them if that's all you're worried about.
* And FWIW I stumbled across a youtube video that shows why you don't want to replace the anode with the aftermarket anode that has a drain spigot on it. This anode showed basically no deterioration in 2 years so it was replaced with an OEM magnesium anode. The magnesium anode was 50% gone when it was pulled after 16 months. The video is by RVGeeks. As the video points out, it's a Good Thing when the anode deteriorates instead of the water heater itself.
Tim
Tim
About Fifth Wheel Group
