Heff560's avatar
Heff560
Suburban water heater replacement
Replaced model SW6DE with SW6DEL. I am now testing prior to caulking the unit in place. The gas heating works perfectly. I shut off the switch that controls the gas side of the heater and let the water cool. I then flipped the switch on the unit to turn on the electric heating element. I let the unit sit over night and there is no hot water. I took the electric element cover off and tested for voltage with switch still on, my meter read zero. The element is not getting power. My fifth wheel does not have a separate switch to operate the electric side of the water heater. Unless someone has a better suggestion, I guess my next step is draining, unhook gas and slide the new unit out to recheck my wiring connections. Any suggestions?
