Heff560ExplorerMay 15, 2017Suburban water heater replacementReplaced model SW6DE with SW6DEL. I am now testing prior to caulking the unit in place. The gas heating works perfectly. I shut off the switch that controls the gas side of the heater and let the wate...Show More
Chris_BryantExplorer IIMay 15, 2017Did you rewire adding a new 12 volt switch hooked to the new orange wire on the unit?
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???Replace insulation inside heater column.Water Heater Replacement RecommendationsReplacement of Suburban water heater...Suburban water heater replacement issue
