BeeTee wrote:
I am looking at a 2008 model year of the above 5th wheel. I'm curious if there are any owners of this same trailer who have taken actual pin weights of this unit. I have the brochure which provides a pin weight but actual weights are likely different. I realize pin weight varies with load but I'm just curious what other owners have weighed in at. My tow vehicle is a 2015 2500 D-Max crew cab and I have empty weights of it. I know I may be cutting it close towing this trailer so I want to get as much info. as possible beforehand.I may be over on GVWR of 10K
but should be OK with rear axle and tire maximums.
Thanks !
At GVW, you're likely to have somewhere between 3300 and 3800 lbs on the pin. Not sure of what the CCC is, but that's =really= cutting it close, IMO, even if you =are= within the RAWR and tire ratings. You'd have to run pretty d@mn light to make this work.
Lyle
