Coach-man wrote:
I am thinking of drilling and tapping two holes one on each side of the center screw to give it more support!?? Thanks for the input!
just shim the sides and it will never move around, before I shimmed mine you could see the movement when I removed the plate as the paint was worn away from back and forth motion, even when the screw was reefed down. Now it is solid and secure
dancoppins wrote:
Have the capture plate either tac or fully welded. We have had a pull rite hitch since 1994 and never had an issue on two different fifth wheels.
if you weld it and you need a tow from another vehicle how will they hook up if you did not buy the adapter
