reddwar's avatar
reddwar
super glide hitch
Well our super glide hitch
all the way to to the back. So can not unhook the fifth wheel. Has this happen to anyone before? We have had it for 10 years with over a 100,000 miles on it. I will not be back till evening thank you.
  • reddwar wrote:
    Yes cdash you are right it was raining last night & I had a blood run {red cross} early today. It will be simple to fix. Thanks
    Think "cdash" easily solved your unhitching problem - now it's time
    to figure out the cause.
    Come back an let us know what you find.
  • Yes cdash you are right it was raining last night & I had a blood run {red cross} early today. It will be simple to fix. Thanks
  • Pull the pins on the head and use the front jacks to lift pin box and hitch head off the hitch?
    Sounds like your capture plate has let loose.
  • Sounds like your adaptor plate has moved or is missing...a little more information would help greatly.
