What I did was to mount the plate with all the screw because that is what it said, BUT later I welded 5/16 square steel around the capture plate with a small space for a gap. then removed all the screws in the plate and put only one larger screw in the space where the plate drops down and now only have to remove one screw to drop the plate. On my 5th wheel flat bed I bought one of their wedges cheaper then a plate no plate now and mounted that to the pin plate on the trailer, works great and has two large bolt to remove to be towed by regular hitch.
