RustyJC wrote:
My last Jayco (a 2000 Designer XL 3610RLTS) came with a vertical pinbox, and Jayco was adamant that I could NOT swap for an extended pinbox due to frame limitations. I'm glad to see you're going with a SuperGlide; if you were still considering going with a Sidewinder, I would strongly recommend consulting Jayco before finalizing that decision.
(Sorry for the edit - my memory is going away, I guess. Our 1996 Jayco was a Designer 3030RKSS, which also had a vertical pinbox.)
Rusty
Yea that is what ours was originally I think, the straight box. Right now it has a 7920 extended box on it. I was going to switch that out to a 7910 that is a little shorter. Don't know if I want to go back to a vertical box.
