time2roll
Oct 18, 2016Nomad
Njmurvin wrote:When I disassembled mine to convert there was some minor wear on the lower side of the tubes. Yes the primary weight and friction is on the top surface. Must be in turns or braking etc. when there are other forces in play on the cam-arm assembly.time2roll wrote:
Initially I also hit the wear surfaces of the cam arm assembly. You really want to hit the bottom of the way tubes also.
That's the first I've heard of lubing the bottom of the tube. I guess it's better to be safe than sorry.
I also finished with a bit of sanding, degreaser and last some BrakeClean to hopefully remove all residue.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
