ALright so i got the job done, i used the wrong grease though. I used Philips/Conoco 66 Megaplex XD5 Grade #1 with 5% moly. I used grade 1 only because it matched the spec in the manual closest to the viscosity at the temperature specified. Does anyone see any problems with this grease? Its also thinner and more workable at cold temperatures so i thought it would make it substantially easier to use the EZ lube feature if I wanted to and reduce the chances of grease popping the seal out. Its actually a construction equipment Lube and i use something very similar on my front end loader tractor. It has a very high dropping point. It says great for wheels bearings on heavy equipment where shock loading or heavy duty is a requirement.
