gary_r1's avatar
gary_r1
supports for silders
Do you use supports on your slides. When they are out or is needed.
Iam new to fifth wheel.
THANK YOU FOR THE HELP.
  • Thats_Ok wrote:
    Kind of thot all those gimmick supports for slides, the hitch and so forth were just one more chore when setting up or getting ready to go.
    Kind of like pitching tents with poles ropes and stakes.
    It can be bad enough with chocks, blocks etc...
    Actually their not a gimmick. Most folks weren't around when our first tips outs/slide outs came on a RV. The supports were required/needed. Some folks made their own.
    Not many of the older trailers left out here that require the slide out supports but I see one every once in a while.
  • old guy wrote:
    stop and think what would happen to your slides if the trailer got a flat tire and the slides had supports under them. far more damage than you can afford out of pocket I bet.
    x2, good point.
    bumpy
  • Kind of thot all those gimmick supports for slides, the hitch and so forth were just one more chore when setting up or getting ready to go.
  • stop and think what would happen to your slides if the trailer got a flat tire and the slides had supports under them. far more damage than you can afford out of pocket I bet.
  • Totally agree with all above but,,,i use them,i have sidewinders for my slides because they are long and wide and I find they really take away a lot of the movement in my rig,do you need them,,no but if you want to lose some of the shimmy in your fiver they really work for me.
  • rhagfo's avatar
    rhagfo
    Explorer III
    robsouth wrote:
    No supports needed for slides. They are engineered to support themselves.
    Stop and think about that 6" casing all the way around the slide out, then add to that the support of the arms underneath, no additional support needed.
  • MFG. don't supply them with rigs because they are not needed.
    Aftermarket sells them because people buy them thinking they are needed........not!
  • No supports needed for slides. They are engineered to support themselves.
