CaptSailor
Jun 07, 2013Explorer
SureFlo water pump question
Howdy,
We've had the SunnyBrook 5th for a few years. Last season I accidentally left the water pump run dry for about an hour without realizing it. Subsequent to that I filled the water tank and the pump appeared to still be working...though it was the end of the season so it was then parked.
This spring I found that with the pump on, and the tank full i get good pressure, but the pump doesn't completely shut off when the tap closes.
I went to the pump and closed the valve from the water tank and opened the Antifreeze valve and put the hose in a pail of water. There was NO suction at all.
I'm assuming I've screwed up the rubber diaphragm in the pump when it ran dry. Does that sound likely?
Can these usually be repaired, or would I be looking to replace the pump?
