raid3r2011's avatar
raid3r2011
Surge Protectors or not??
Hey, Y'all. I downloaded a list from someone on the internet & one of the things it recommended was to get a Surge Protector. It went on to say that some of the sites hook up devices are not in good shape & it would be safer to have one. Anyone have any comments?
  • Surge protection per-se is less necessary than the voltage protection and verification the wiring is correct with proper polarity and ground.
    We frequently get posts of people plugging into 240v and burning stuff up, hot skin from reverse polarity and bad ground. And these are not just at campsites... they are also right at home or a buddy's house where you think all is safe. Also plenty of posts with low voltage suspected when the air conditioner quits.
  • raid3r2011 wrote:
    I think I will get one. Where does it go?
    Tie a knot in a power cord. That is a surge protector.
    Why do you assume maybe 15 different items are same? Expression 'surge protector' (for RVs) has little relationship to a same expression for homes. And is completely different from the expression that applies to a USB port.
    He said you need a magic box. So that proves you need a magic box? Even a knot in a wire does surge protection. Do you really need that?
    That need is not being cautious. It demonstrates how easily scams can be promoted.
  • The first time you have to replace an AC unit due to low voltage damage you will wish you had one. I recommend this company, http://www.progressiveindustries.net/ , They offer a lifetime warranty and have excellent customer support. I would suggest spend a little more and get the EMS series which protects from surges, over voltage, under voltage, miswired connection, and does a checkout of the power available before it is ever applied to the RV. If you plug in and there is a problem with power there will be no power to the RV that could damage it. Especially nice if you have 50A service and the pole has a bad neutral which will put 240v on the 120 circuits. It won't turn on.
    Some like the portable, mine is hardwired. That way if there is a problem at the pole, with my power cord, or the connection on the side of the RV it won't turn on.
    My 2 cents worth.
  • bpounds wrote:
    I've never had one. Have not missed it.
    I know what you're saying. I am an overly cautious kind of guy. Must be from my motorcycling days.
  • raid3r2011 wrote:
    momentum rv wrote:
    Do it... if it saves you just once it was worth it. But not just surge protection but also low voltage, high voltage, reverse polarity etc.
    It goes between the power pedestal and your trailer shore power cord. This is what I use for 30 amp needs.
    Progressive Industries EMS-PT30C Portable RV Surge Protection 30 Amp
    Got it from Tweetys
  • Do it... if it saves you just once it was worth it. But not just surge protection but also low voltage, high voltage, reverse polarity etc.
