- BillB3857ExplorerContact the manufacturer had insist that they send a mobile mechanic to take care of this problem and properly inspect all other suspension parts.
- The_Mad_NorskyExplorer
RAS43 wrote:
It looks like the hanger legs are bent and the weld is breaking loose. You may need more then a bolt.
:h
I was kind of wondering the same thing.
Although I give the OP the benefit of it is just the camera angle used in taking the photo here.
Here's to hoping for a simple fix and solution to your problem. - fj12ryderExplorer IIIThe shackle is probably bent a bit too, and the hole will no longer be tight for a new bolt. I'd call the dealer, explain the situation, and see what they want to do about it. You need to let the dealer know because if you have issues with this shackle, or the hanger, or the spring, at a later date you'll be able to say that you had a problem earlier and notified them. Just a CYA.
- RAS43Explorer IIIIt looks like the hanger legs are bent and the weld is breaking loose. You may need more then a bolt.
- Wood_chipExplorer
Goostoff wrote:
I would call the dealer and make them come to your house to fix it. If you fix it they win, and it isnt fit to be on the road like that.
The dealer is 200 miles away so I will fix it myself. The bolt is bent so I will need to replace that bolt. - Wood_chipExplorerI will need to take the weight off that spring to see if I can jar it loose
- Bionic_ManExplorerThat would be exciting going down the road....
- GoostoffExplorerI would call the dealer and make them come to your house to fix it. If you fix it they win, and it isnt fit to be on the road like that.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 12, 2025
