CA_Traveler
Jun 10, 2023Explorer III
The first thing I would check is battery voltage. The most likely areas for a leak is the hose ends, cylinder or hydraulic pump area and should be easy to see or feel.
If you have the type that are all slides in or out vs individual slide control then I would expect an internal cylinder leak is causing the slow slide issue. ie A slide is in but the cylinder leak is returning fluid to the pump. No personal experience with this.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
