heyobie
Jun 10, 2023Explorer
The bottom is sealed. I have 4 slides of which 3 I can not see. The slide in the bedroom under the bed is not leaking.
I have 6 leveling jacks which I do not see any oil.
So, the plan is to
1. check the battery voltage at the pump.
2. Assume the leak is the problem and find it.
But the system has worked fine with the disappearing oil and it is not pumping oil out. The pressure seems to be holding just fine.
When I closed the slides (I have a single slide switch), they retracted at a much slower rate than the last 15 times. It seems like it is running at 1/2 power.
While I may have a misterious leak, I am not loosing that much oil to cause my slides to move so slow. If the leak were bad, the oil would be pumped out.
So, the plan is to
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
