CA_Traveler
Jun 11, 2023Explorer III
2009 The pump was replaced just under the 2 year warranty, sent me the upgraded pump and made it clear no coverage for installation. Helpful in that sense. The Lipper inner plastic hose tends to leak with 2500 psi and then it runs inside the outer plastic hose to the end connector to leak in my case.
With an cyclinder seal internal leak the oil would flow from the pressure side to the non pressure side with no leak evident.
Lipper can supply quality equipment if ordered by mfg but most want high volume lower cost & quality equipment.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
