Wife wants a sxs, been thinking of the new Honda 700-4place. The trouble starts when loading the sxs into the DF TH, max clearance height under the bottom double bunk is 72-1/2". No sxs I have look...
A lot of SxS have low ground clearance unless you add the lift kit to them to give you more clearance over rocks, logs, mud etc. Even if you don't buy the lift kit now, I think you should build it into your plans. And better tires are usually a little taller.
