How much tail length is too much to make tail spin problematic or damaging as when leaving the gas pump? My 5er has 12' overhang at the rear. A 38' I'm interested in buying has 17' tail at the rear. T...
I might worry about tail swing with a TT but not with a 5er that tracks inside of the PU pulling it in a turn. The tighter the turn the more it tracks inside so even in a turn where the PU is at it's best/tightest turning radius I doubt the back of the trailer will be further out than the back of the truck. Now if you back up and get the 5er 90+ degrees to the truck in a turn you can get the inside tires of the trailer to go backwards and tail swing WILL be a issue.
