Ramblin__Rosie's avatar
Oct 22, 2020
Tail light issues
We have a Winnebago Outlook 331C. The tail lights use the two filament bulbs that are commonly found in trailer light for the brake and turn signal, plus a single filament bulb for the backup light (refer to the attached picture.) We are having chronic problems with the two filament bulbs coming dislodged, thereby making the brake light and/or the turn signal inoperative. Removing the lens and jiggling the bulb solves the problem, but the problem re-occurs after we get back on the road. IS there any effective solution to this problem?
Is there any way to replace these light fixtures with LED fixture? If so, can anyone recommend a specific product? Ideally, I would prefer something that can be surface-mounted, so I don't have to cut holes in the fiberglass for a recessed mounted fixture.
Tail light picture
