lamopar
Jan 17, 2016Explorer
I purchased chains for my truck and trailer. I have a heavily winterized trailer already that has full insulation under and tank heaters. I have been in it at about 18 degrees with no problem other than the water supply would not work. It was fine as I have 150 gallons of fresh water on board. I am going to check out the tips. I have only driven on about 1/2" of snow on the pass coming back from Bend once and didn't have any problem but there was no ice under. I definitely will leave if it looks like the weather is getting bad and if the weather is too bad leaving it there is a good idea. I'll post after we get back as long as the good skiing holds out. Going at the end of the month. Thanks for all the tips.
About Fifth Wheel Group
