Rangerman40's avatar
Rangerman40
Talk to me about washing machines
So our new fifth wheel has a washer/dryer prep. I've looked online and all of the rv specific units seem to get mixed reviews, and take forever to do a load. In talking to my wife about it she's not even sure we need a dryer because she dries very little at home. Does anyone have any recommendations for a washer only? I like the idea of an apartment sized stack unit (if it will even fit), but less than thrilled about having to drill a hole in the side of a brand new fifth wheel for a vent. The combo ventless units look fairly useless to me. It's one of those things that doesn't really do either task well and is highly inefficient about doing it.
  • We had the vented combo unit in our previous 2 5ers and had no problems. Friends had the non-vented unit and she hated it with a passion as it ruined some of her clothes.
    We opt'd for the stacked units in our current unit and love them.
    Because as a rule we don't get our clothes filthy we use one of the shorter cycles on the washer to reduce the time.
  • I could go on and onot with this subject. People that have them love them people that don't claim that won't give up the space for them. I've had both the Splendide vented and the stackable set. Definitely would not be without one or the other. The stackable is definitely better and easier to use. The Splendide took more understanding and did much smaller loads and you really need to read the manual and make sure you did it right or everything came out TERRIBLY WRINKLED but if you took your time and looked at the manual and set it correctly it was great. Set it up and go about your day. That being said my wife always complained about the Splendide because she didn't want to spend the time to learn the different settings and what they did to the clothed. She did love the stackable as it was just a smaller version of our home machines.
  • We have the Splendide stackables and would not be without them. The washer of course has smaller capacity than a home washer but has a variety of settings and we have not had any problems at all with it. The dryer is 110 vice a 220 home dryer so it does take longer to dry. We have had to change the thermostat on the dryer but other than that, it has also worked just fine. We can wash everything except for our quilt. Some say they take too much time or too much space. Our 5th wheel has a closet for the units and we wash clothes whenever we want to usually while sitting in our pjs so it does not interfere with our full timing lifestyle at all. We find laundries to be filthy places and you never know what has been in the washer before you put in your clothes. For us, it is worth the expense.
  • Just curious to know what DW does with a load of wet clothes on the RV?
  • I have the Splendide 2100XC and would absolutely not full time without it. Works great, and has been 100% reliable for the past 6.5 years. As others have said it does small loads, but then we are living in a small space compared to our s&b's. I use mine as a dirty hamper for colored clothes and run when full enough to run. Add soap, turn it on and go on about my day. I really don't care that it takes 3 hours to finish. White dirty clothes go in the clothes hamper that is built in to my rig. I have to wash whites less than colors since I have a lot of whites.
  • We have Whirlpool washer and vented dryer. They work great, albeit the loads are smaller, but this has yet to be an issue. The dryer is 120 volts so the clothes don't dry as fast as a home dryer, but that's okay as we are in no hurry while camping. The hole through the side wall for the vent is well sealed and we haven't had any issues. Will never have an RV without them.
  • donn0128 wrote:
    Vented combos work very well. The only real caviot is small loads. When were out, we usually do a load a day. Load, add soap, press start and go do our thing. Later when we get back home, take out clean dry clothes. BTW most all private camp grounds do not allow line drying of clothes. Besides it really looks tacky. We would be be without for extended time on the road. I am simply not a fan of laundrymats.
    No line drying for us outside the camper. We have a multi level drying rack that we put the clothes on and keep it inside. Works pretty well. My wife has some aversion to drying anything in a dryer. I think it's because she's almost 6' tall and her clothes are barely long enough on her to start and even a little shrinkage in a dryer is a no go for her..... me I could not care less either way.
  • We have a ventless Domestic combo and prior posted was correct in starting a load and come back in 3 hrs to clean dry clothes. Also did not want hole in side of our 5ver. On sale last year at rvpartscountry for $645 versus $1300 for stacked pair and it only uses about 12 gallons of water per load.
  • Vented combos work very well. The only real caviot is small loads. When were out, we usually do a load a day. Load, add soap, press start and go do our thing. Later when we get back home, take out clean dry clothes. BTW most all private camp grounds do not allow line drying of clothes. Besides it really looks tacky. We would be be without for extended time on the road. I am simply not a fan of laundrymats.
