- Cydog15Explorer
JIMNLIN wrote:
I don't see any on the road.
Since the industry came out with 17.5" trailer wheels and some good 14/16 ply road tires there really is no need for tandem dual axles in the rv trailer market....and fed regs let rv trailer makers use less GAWR than GVWR.
And tri axle trailers do a job better....the load is spread over the trailers frame in a longer area for less hitch weight/3 axle braking/less chucking issues than two axles/etc.
Thanks. I only see the Newmar products with them but since they stopped producing 5th wheels, haven't seen any others. - JIMNLINExplorer IIII don't see any on the road.
And tri axle trailers do a job better....the load is spread over the trailers frame in a longer area for less hitch weight/3 axle braking/less chucking issues than two axles/etc. - Luke_PorterExplorerNewmar was the only one to use the tandem duals. I had a 2004 Mountain Aire (towards the end of the good ones) that I put well over 200,000 miles on. Had a few blowouts and a couple of broken springs (imagine breaking a spring in only 200K). But I always had spare tires and spare springs.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
