Second_Chance
Dec 29, 2017Explorer II
We have weathered lows at night in the 10 - 11 degree range with high winds for five nights. We ran the main furnace (set at 68 inside) and had a ceramic heater on a ThermoCube in the basement to supplement. We still had frozen water lines to the kitchen island which is amidships. Not everything under there is protected to the same degree. During that "incident," I cut a flap in the underbelly, thawed out the Pex lines, put the foam noodle pipe insulation over as much as I could and put two layers of Reflectix between the Pex lines and the underbelly. We haven't had a problem since then. We've also stayed farther south at that time of the year.
Rob
Rob
About Fifth Wheel Group
