padredw
Dec 30, 2017Nomad
Tony B wrote:
Do i need to winterize and what do I have to do?
Tony, I'm up here in North East Texas and I have winterized several weeks ago. If I had not, I would surely do so today in light of the predictions for the next several days.
1. Drain your fresh water tank. Mine has a valve. If you know where your drain is, fine; if not, find out now.
2. Drain your hot water heater. Mine has a plastic plug, some have a metal one. Mine also has a faucet at the top which I open to allow air in for faster drain.
3. Open all spigots inside the trailer--while the water heater is draining.
4. locate your "low point drain." The valves for mine is inside the front storage bay, but you need to find out where yours is.
5. I use the "forced air" method. You will need a special adapter for your fresh water (city water) inlet (where you attach the hose) which has a valve stem (such as on your tires.) I use my air compressor to force out the remaining water.
NOTE: This "forced air" method has always been sufficient here in our part of Texas--temperatures in the teens. I have never used the full anit-freeze liquid method. Just in the P-traps and toilet bowl. If it got down into the single digits for days that would be a different matter. Over 20 years, I've never encountered that situation.
About Fifth Wheel Group
