CKNSLS
Jun 15, 2013Explorer
larry barnhart wrote:
I have noticed this on many lippert framed fifthwheels. I also have noticed some new lippert framed fifthwheel with a control crack cut and a T-shaped molding installed this can be done for your problem. If it doesn't have a big problem that isn't known of course and my guess is you might not. The corner is a weak spot. If you notice when concrete is poured around an existing concrete slab the sharp corner will crack the new concrete and rebar is added to maybe stop it from the stress of the old corner. Enjoy your fifth and let us know the fix.
chevman
Have you noticed this on other frame manufacturers? There are more Lippert frames out there than others.
About Fifth Wheel Group
