Dayle1
Oct 06, 2018Explorer II
Ralph Cramden wrote:newman fulltimer wrote:
Well the good news .that's not a frame failure that's a wall stud weld failure theweld broke at the slide side wall and when slide pushed out it pushed the wall out causing the crack. Note the crack starts in the corner going outward
Do you have Xray vision? LOL.
I have seen more than one different brand of 5er with a crack in that same location due to frame flex and cracked welds or steel near the pinbox. What they all had in common was LCI.
First key point would be how much does the pin flex loaded vs unloaded. If it is less than 1/2" then frame is OK, if more then frame and wall stud are both suspect. Just my opinion but I would expect just a hairline crack if the wall stud next to the slideout failed, not a significant gap.
About Fifth Wheel Group
