SidecarFlip
Oct 06, 2018Explorer III
Old-Biscuit wrote:
Have you removed the overhang panel and inspected the pin box/overhang structure for failures?
Also check if side wall is no longer attached to overhang horizontal beam
Watch for movement when you load/unload pin box with overhang panel removed
If that was mine, I'd bevel them, lay on fishplate on one side and fill with weld and weld on the fishplates. Issue solved. The weld on your one picture has no penetration at all. Not enough amps or too fast travel speed.
About Fifth Wheel Group
