Michelle_S
Oct 06, 2018Explorer III
That is a weak stress point in the wall, very common on many brands. Many now come from the Factory with a vertical cut at that point with a molding section inserted into the cut.
I would do the measurements on King Pin movement and if within specs, make a clean cut where your crack/tear is and insert a section of molding to seal it.
About Fifth Wheel Group
