IAMICHABOD
Feb 29, 2016Explorer III
Jbrowland wrote:
I hope the OP got it all situated easily. I searched and found this thread. Not to hijack but, I noticed my entrance window on my class C is a little loose and I can move it up or down about two inches. Those screws in the plastic around the edges on the inside are all that is holding the window in place and preventing it from moving?
This happens sometimes,there are small tabs on the inside of the frame that keep the window in place,they will sometime break after a lot of use, letting the glass move inside the frame.
To correct it you can put a new frame in that the tabs are in place or do as a friend did and glue it in place.
I decided to go another route when I had the problem.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
