GrumpyandGrandm
Aug 19, 2015Explorer
Humpty wrote:
Adding the 2nd AC was the best thing we ever did. Hardest part of the job is getting the unit on the roof.
X-2 If your handy it's an easy job, I've done about 6, couple for myself and the rest for friend.
rrbowman wrote:
How were you able to connect a thermostat to the new unit? Is there a second thermostat for the bedroom AC?
If it is pre-wired for a ducted unit the wires are probably already there. If not you just use the standard a/c grill that has the thermo and fan controls built in. If your going to tackle it yourself remove the trim ring for the vent and see what wires are there. The thermo wire will have about 6 wires in one sheath. You would then have to ask JAYCO where they would have put the thermo on the wall to find the other end.
About Fifth Wheel Group
