agesilaus
Aug 30, 2019Explorer III
You can replace slide motors, if that is the problem. Cost me about $125 at the local RV parts dept for our old Titanium.
For the window I'd just pull the whole window out and take it down to a local glass dealer. They will fix it and you just put the window back in with the proper sealant.
No suggestions on the vinyl. A tankless heater means you won't have hot water if you are no hook up. You might want to check online for RV Salvage to see if you can buy a used heater. Or it might just need a new element. You can by controller parts for water heaters on Amazon, some heaters anyway. What can go wrong with a heater anyway unless it's rusted out?
About Fifth Wheel Group
