Jim4929ExplorerAug 17, 2013Third Dometic 9100 Awning FailureToday I returned home from having a THIRD motor put in my Dometic 9100 series awning. I extended it to dry out the awning and tried to retract it and the same problem occured....tink tink when the but...Show More
Mandalay_ParrExplorerAug 17, 2013Has the torsional spring on the other end been adjusted or replaced? If not proper, it would cause extra motor load.
Related ContentDometic Oasis Elite power awning failureDOMETIC FAILURE!Dometic awningCarefree awning failureDometic awning issue
