topjimmy
Aug 17, 2019Explorer
My thoughts Exactly I have had 2 5er's with auto level and been a fulltimer for 7 years and I have rarely had a problem auto leveling but just like CarnationSailor said I do sometimes put a few of those orange blocks on the middle and rear jacks from getting Hyper-extended and by the way I have had my wheels off the ground MANY times and the jacks can handle it no problem just a little more wobble inside that's all and also anybody that is manually leveling with auto level is not doing something right or they need to recalibrate the system
CarnationSailor wrote:
I just can't bring myself to manually level the 5th when I have auto-level available, so I never pre-level by putting blocks under the tires. and also anybody that is Manually leveling with the auto system is not doing something right or you need to recalibrate the system
At first I was concerned about the tires being off the ground, but then postings on this forum convinved me that the jecks are designed to carry the weight of the trailer when the tires are off the ground.
Also, after observing all the Class A's with their front tires off the ground on sites that are barely out-of-level front to back, I am further convinced that tires off the ground is not a problem.
However, on an unlevel site, I do use blocks under any jack where they are needed to prevent the jack being "hyper extended".
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
