laknox
Aug 28, 2019Nomad
cougar28 wrote:
Our new Jayco has the auto leveling system. So far we have used it twice and both sites we were off level side to side not over 2" and I did block the low side.Not sure if I even need to less the 2". So how far off level side to side before you start blocking?
Personally, I put at least 4" under my rear jacks due to the fact that they just don't have a lot of travel. On the street in front of my house, there's enough crown in it that the RR jack runs out of stroke by about an inch. Adding that 4", on both sides, gives me plenty of assurance that, on all but the most unlevel site, I'll have enough stroke on the rear jacks.
On the front, I =always= put at least one lego block down (don't need them for the wheels, so why not?) as a pad. I do carry plenty of blocks with me, just in case. I normally power down the front jacks a fair ways before dropping the extensions. I drop the extensions to the ground, then pull them up until the pin snaps into place. After that, I jack up, unhitch, then hit the Autolevel button. Once it's done, I raise the front just a bit, tighten the JT Strongarms, then drop the front back to level.
Last time we went out, though, we were boondocking in the forest and, after a bit of rain, noticed that the rig was wiggling a bit on the last night. Didn't really pay much attention, but when I was packing up, I noticed how much we'd settled, close to an inch, and it =did= make a difference. I'll pay attention to that in the future and simply re-level, if necessary.
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
