laknox
Aug 30, 2019Nomad
austinjenna wrote:
I dont have the leveling system but I am sure the next one will. So do you guys put the between tires chocks in? or do you just use chocks on the ground in front and rear of the tires. I was just thinking of my normal routine, chocks between the tires and then in front and read of the tires. Just wondering what happens if the leveling system raises the tires off the ground and what happens when you want to hook back up how you do it.
In my experience, I've often had one side off the ground, or very close to it, so chocks would be useless on that side. As I said above, my system wants to level UPWARDS, so even the high side wheels can be somewhat unweighted. I chock my trailer before leveling and, when done, those chocks will be loose on the "high" side. If I kick them in tight, then forget to pull them back before hitching, the trailer locks them in place and I'll either have to re-raise the trailer to get them out or rock it. This is why I put my chocks =between= the wheels, so that I can at least move my trailer in one direction, if needed, to get the chocks out. Again, as I said above, I'd love to have an option to drop the whole rig, level, about 1-2".
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
