cougar28's avatar
cougar28
Those with auto leveling systems
Our new Jayco has the auto leveling system. So far we have used it twice and both sites we were off level side to side not over 2" and I did block the low side.Not sure if I even need to less the 2". So how far off level side to side before you start blocking?
  • I run into this problem with my Montana 5er all the time. After many times getting error codes, my dealership repair shop guy finally told me those Lippert Leveling systems do not have much tolerance. You need to get your trailer as level as possible, side-to-side before using the system. That means ... ALWAYS setting up the 5er just like we did with the 3 previous trailers... with a carpenters level and lumber under the tires.
    Mine has a tolerance at 2 degrees. When it hits 3 degrees, the auto level does not work. I carry lumber and level as close as I can (side to side) wherever we go before extending the jacks.
  • 12th Man Fan wrote:
    Should not be off level at all. You need to reset the system. You can manually level the rig and then save this info depending what type of system you have.
    Not saying the system is off. When you first get on the site and your rig is off level side to side. At what point do you put blocking under the wheels on the low side to get close to level before useing the auto level system.
  • From a strength perspective, it's not needed. However, with wheels off the ground, you will get more wiggle. I try to add a board or two under the low side to help avoid that.
  • Should not be off level at all. You need to reset the system. You can manually level the rig and then save this info depending what type of system you have.
