N-Trouble wrote:
Kind of crazy but I can fit a Rhino, Raptor 250, and LT50 in my lil ol Weekend Warrior FK19. And with the Rhino in the back tongue weight isn't that bad and I can get another full size quad in the back of the truck and sit level while towing. We are starting to outgrow the trailer though.
OP just watch your pin weight with the SRW setup. 5er is the way to go if you have the truck for it.
Thanks for the info. I should be good on pin weight for all but the biggest TH's....payload capacity of truck should be about 4200lbs give or take (which is why I want to stay away from the 40ft'ers and the 16000lb GVWR th's...thinking 14k max would be about as high as I would want to go...but them big ones sure are nice!!
