- MartyMooseExplorerHeck, I don't even pull up my carpeting in the garage anymore. I just put down my HF chock, ride it in and strap it down.
I did have a strap come loose once as I didn't think I had to really crank it down. Luckily the wheel chock did it's job and held it up. No damage.
Lesson learned... crank it down with the straps hard. - LowRyterExplorer
bluwtrman wrote:
LowRyter wrote:
I use two of those $39 HF chocks. I strap them down with rubber mats underneath. I can place them where ever I want depending on how many bikes I am carrying. And I have a clean floor when not carrying anything.
Do you have any pics of this setup? Are you saying the chocks are just sitting on the rubber mats?
I use two straps on each chock (front and rear) + 4 straps on each bike.
- joebedfordNomad III
bluwtrman wrote:
Nothing but dust and wires lying on the coroplast which I didn't remove as I was able to pull down the back corner to get access. The floor itself is insulated.
joebedford - I assume there's just some insulation laying on top of the caroplast? Also, did you put in backing plates or just fender washers? - bluwtrmanExplorer
Do you have any pics of this setup? Are you saying the chocks are just sitting on the rubber mats? - LowRyterExplorerI use two of those $39 HF chocks. I strap them down with rubber mats underneath. I can place them where ever I want depending on how many bikes I am carrying. And I have a clean floor when not carrying anything.
- Y-GuyModeratorI didn't remove my corrugated plastic, but I did cut 3 sides so it could hinge open. No insulation in mine and unless they tell you there is some most consider the corrugated plastic to be the "insulation" When I was finished I used 2 zip ties and some very sticky black tape (like Gorilla tape) to hold it in place.
- mapguyExplorerThrough bolting with backup plates or into frame members is the only way the existing floor will take the load -long term. Remember most TH's use some version of engineered sheet goods (OSB)or a luan plywood/foam sandwich for subfloors. These sub-floor systems get soft very easily....
- bluwtrmanExplorerjoebedford - I assume there's just some insulation laying on top of the caroplast? Also, did you put in backing plates or just fender washers?
gbopp wrote:
Actually I've had them so long I'm pretty sure I paid the full price at the time: $29.99joebedford wrote:
My $39.95 chock from HF works just fine for both mine and DW's Ultras.
But, did you use a 20% off coupon :@ - gboppExplorer
About Fifth Wheel Group
