- pianotunaNomad III
StirCrazy wrote:
pianotuna wrote:
best all around battery is SiO2. Pocket book "ouch".
First report I've seen on facebook of someone who disconnected their Li battery in the fall at 50% state of charge. Temperature was -5 c (23 f)at the lowest. Now they have two expensive door stops.
Cuz face book is always true of course.. I thought you would have stopped your smear campaigns by now.
You need to calm down. I have a right to my opinion. For me SiO2 are the best possible fit other the Lithium Titinate. - StirCrazyModerator
Connor24 wrote:
I use it for lights and refrige while boondocking. Refrige running on gas.
lights eh and how long do you go boon docking for? do you have solar, if so, how much and do you have a generator?
Steve - StirCrazyModerator
Cuz face book is always true of course.. I thought you would have stopped your smear campaigns by now. - JBarcaNomad II
Hi,
No one asked yet, and you did not state, so in case you did not know,
Regardless of what battery you get, if you are using the battery for lighting while boondocking, I suggest if you are on incandescent 921 light bulbs, convert them to LED lights. Many, if not all, older campers were set up on incandescent 921 light bulbs. You can save 4 to 5 times the power, per bulb, by converting to LED.
Only asking "the best brand" questions leaves a lot of info out of the answers you will get. Nowadays, many folks are converting to more expensive battery technology to get other benefits from the battery that fits their camping needs. Converting to the new Lithium or other technologies costs more, gives other benefits, and the brand's change. The brand alone does not indicate what you need to get good service for how you use your camper.
If you stay with older technology and go with lead acid deep cycle batteries or a Marine/deep cycle (if you cannot get a true deep cycle,) the cost is less, and they can last a long time if the battery is maintained and used correctly.
I have not leaped yet to the new technology; I do not use an inverter, but I have a slide motor and a power tongue jack to run when boondocking. I am still on the old-school lead acid batteries and use and maintain them to get the longest life. Only draw down to 50% state of charge before recharging, use a good power converter with a desulfation mode, keep the electrolyte level where it needs to be, and when not camping, put the batteries on a battery maintainer with desulfation mode to keep the batteries stored at 100% state of charge. We also camp in freezing weather but plugged into shore power.
For our needs, we boondock using 2, group 27 marine/deep cycle batteries connected in a balanced configuration from Walmart. Johnson Controls makes them. The set I load-tested last week comes up with the marine cracking amps still above the rated batteries from my Walmart batteries installed in 2014. That is nine years from a Walmart set of batteries. The first set went seven years, and I changed them due to age, as I did not have a load tester then. They fit our needs and do not cost that much. But you must use and maintain them to get this kind of life out of them.
Suggest figuring out your battery use requirements and how to use and maintain them properly. Then figure out what cost and style battery fit your needs. On the older technology of LA batteries, most die a short death mainly from improper use and no battery maintenance. Some brands may handle more abuse than others.
Hope this helps
John - MFLNomad II
ScottG wrote:
2oldman wrote:
Connor24 wrote:
That's it? A used car battery would handle that.
Yeah but who's gonna buy a used car just to get the battery out of it? ;););)
It's good to see that a respected, helpful member, also can show that he has a sense of humor!:C - Grit_dogTrailblazer
Best response yet! - TvovExplorer II
How long are you boondocking on average? We usually go to a couple state parks that do not have hookups, and our battery easily lasts 2 nights and days - just remember to only use lights when you really need to.
And we get our batteries from.... Walmart! Yep. Work fine.
If I was regularly "boondocking" for like a week at a time, yes I definitely would get whatever is the best battery. Which from my understanding would be a twin 6 volt battery setup.
On the other hand, we also have a Honda EU generator we can run (if allowed) which means the battery just has to last through the night. - ScottGNomad
Yeah but who's gonna buy a used car just to get the battery out of it? ;););) - Boon_DockerExplorer IIIA pair of GC2 batteries (6v deep cycle golf cart), best bank for the buck.
Nope not even close. But you already know that, so the response is curious….
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
